Deluxe Steering Wheel
MaxKlinger
Post by MaxKlinger »
I'd like to have a pre-1971 Deluxe steering wheel on my truck. That's the one with the horn ring in it, like the blue one pictured on the right on this page:
http://www.fordification.com/67-72ID.htm
Is it possible to add a horn ring to any three-spoke steering wheel, or is the wheel itself different between the Deluxe and the standard wheel?
Thanks!
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
71PA_Highboy
re: Delixe Steering Wheel
Post by 71PA_Highboy »
Wheel is different... they are a matched set.
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
ezernut9mm
re: Deluxe Steering Wheel
Post by ezernut9mm »
what's different about them? i always thought they were interchangable.
dcbullet
Post by dcbullet »
I'm quite certain they are the same wheel.
theogre5150
Post by theogre5150 »
They are the same except for the horn ring. Tony you can order these steering wheels through NPD with the horn ring. Look on page 79 and 80 in the NPD catalog. The horn right is around $70 and the steering wheel is from $159 to $199. I'm going junkin' this weekend and I'll keep my eyes open for one.
MaxKlinger
Well I'm sure the reproduction deluxe wheels are beautiful but $300 when all is said and done is pretty expensive. That's why I was looking to recondition an old standard three-spoke (like the one you have, Eric) and then add a horn ring to it if possible.
Mjhaltom (project Uncle Darrell) made a good suggestion, about getting an older wheel and filling in the cracks with JBWeld. Then it could be sanded smooth, a few coats of paint and a repro horn ring to dress it up should make a nice looking wheel for about half of what a brand new wheel would cost.
Eric if you see anything out there let me know, I appreciate it.
Tony
theogre5150
I still have this wheel if you want it. I'll let you know what I find this weekend.
when and if you change your wheel you have to grind off that stub on your steering wheel shaft in order for the horn ring to fit on the wheel.
lightning_msd
Post by lightning_msd »
ok so can anyone tell me what year this steering wheel is from, i didnt think that 67 came with cruise control on the steering wheel yet...
i would say 72 up into the 80s they made a wheel like that. with the cruise in the horn button area. look for a part number inside the pad next time you take it off.
lightning_msd
:lol: i just went out and looked at it, and my 79 was just like it, but it had woodgrain, this one someone took off the woodgrain, or it fell off, and they painted it, not a very good paint job either.... thanks guys... :lol: sorry if i hijacked this thread...
MaxKlinger
fordman wrote:when and if you change your wheel you have to grind off that stub on your steering wheel shaft in order for the horn ring to fit on the wheel.
Yeah I'm aware of that. It should be relatively straightforward. Thanks fordman.
Tony
