Deluxe Steering Wheel
- MaxKlinger
I'd like to have a pre-1971 Deluxe steering wheel on my truck. That's the one with the horn ring in it, like the blue one pictured on the right on this page:
http://www.fordification.com/67-72ID.htm
Is it possible to add a horn ring to any three-spoke steering wheel, or is the wheel itself different between the Deluxe and the standard wheel?
Thanks!
Thanks!
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
- 71PA_Highboy
re: Delixe Steering Wheel
Wheel is different... they are a matched set.
hth,
eric
hth,
eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
- ezernut9mm
re: Deluxe Steering Wheel
what's different about them? i always thought they were interchangable.
They are the same except for the horn ring. Tony you can order these steering wheels through NPD with the horn ring. Look on page 79 and 80 in the NPD catalog. The horn right is around $70 and the steering wheel is from $159 to $199. I'm going junkin' this weekend and I'll keep my eyes open for one.
- MaxKlinger
Well I'm sure the reproduction deluxe wheels are beautiful but $300 when all is said and done is pretty expensive. That's why I was looking to recondition an old standard three-spoke (like the one you have, Eric) and then add a horn ring to it if possible.
Mjhaltom (project Uncle Darrell) made a good suggestion, about getting an older wheel and filling in the cracks with JBWeld. Then it could be sanded smooth, a few coats of paint and a repro horn ring to dress it up should make a nice looking wheel for about half of what a brand new wheel would cost.
Eric if you see anything out there let me know, I appreciate it.
Tony
- lightning_msd
ok so can anyone tell me what year this steering wheel is from, i didnt think that 67 came with cruise control on the steering wheel yet...
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
- lightning_msd
- MaxKlinger
Yeah I'm aware of that. It should be relatively straightforward. Thanks fordman.fordman wrote:when and if you change your wheel you have to grind off that stub on your steering wheel shaft in order for the horn ring to fit on the wheel.
Tony
