Where oh where can i get one of these???
- 72bumbee
I've looked at most major parts places and catalogues...
I've looked at junk yards...
I've looked at Ford dealerships...
Can YOU help?
This is the cause of the coolant leak and the threaded stalk is now so corroded that pipe goop cant even help it.
Can YOU help?
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
- colnago
Re: Where oh where can i get one of these???
I bought a taller one from O'Reilly's last year. I'm on the road, but when I get home, I'll try to find a part number. You can also try eBay and amazon.
Joseph
Joseph
National Parts Depot has them brand new for an FE Mustang. Same thing
- 72bumbee
I’ve found them with one nipple but not two nipples.
I still don’t even know what it’s called????
Mark Twain
Mark Twain
- Ranchero50
I think they are truck specific since the carb heat plate is also a flow bypass for when the heater valve is shut.
- colnago
I couldn't find what I used, but if you go to O'Reilly's web site, and search for "Murray heater fitting," you can hopefully find a replacement. Mine sticks up to clear my intake manifold, but if Ford used a short one on your manifold, you should be able to find something. I don't remember the thread pitch or pipe size, either. I know that I did not get one with a tube that goes down into the manifold.
Joseph
Joseph
I can get you a used one if you like.
1967 F-100 4x4 custom cab.
These are available all over the place stock type > https://www.macsautoparts.com/ford_must ... 2-v-8.html
Aftermarket version>> https://www.speedwaymotors.com/Bills-Ho ... 78486.html
One more>> https://www.ebay.com/sch/i.html?_from=R ... e&_sacat=0
The issue is trying to find the one with two outlets. probably will have to use a “T” or “Y” in the hose and use one of the single outlet ones unless you can find a good used one.
- Gray035
Here's one for an older Bronco. They are mostly small blocks, but maybe it's the same.
https://www.tomsbroncoparts.com/product ... bronco-new
1968 F-250 Camper Special
- Ranchero50
Nope, single pipe is for everything other than a truck. Trucks use the dual hose setup so there is still flow when the heater valve is shut off.Gray035 wrote:Here's one for an older Bronco. They are mostly small blocks, but maybe it's the same.
To the OP, drain your coolant, remove your fitting and clean all that teflon crap off. Spray some brake clean on the threads and put a dab of Permatex Ultra RTV on it. Let it set up overnight and refill.
- 72bumbee
So I’ve checked several links and they were all single outlet style
I need the dual outlet unit
Mark Twain
Mark Twain
- 72bumbee
Can you send a picture of it and price?Busboy wrote:I can get you a used one if you like.
Mark Twain
Mark Twain
- 72bumbee
What’s OP in the above quote?Ranchero50 wrote:Nope, single pipe is for everything other than a truck. Trucks use the dual hose setup so there is still flow when the heater valve is shut off.Gray035 wrote:Here's one for an older Bronco. They are mostly small blocks, but maybe it's the same.
I was hoping to find an original but I’m okay with doing the “Y” option also... I’m not a purist as much as I am a cheapist.... haha!
Is permatex Ultra RTV a silicone, rubber, gasket material type stuff? I think I may have a tube of it on hand.
Still might have a chance at an original two port jobby if busboy comes through...
I’m still left wondering why these are obsolete???
Any ideas or should I not second guess the Ford engineers??!!??!!
Mark Twain
Mark Twain
