Can anyone help me identify this seal? I recently fished this out of the filler neck of my radiator and I have absolutely no clue what this is, where it came from or how it got in there to begin with.
[image]604[/image]
[image]603[/image]
I figure since it was fished out of the top of the radiator, it must have entered through there as well unless the truck was run without a thermostat at some point. Maybe it's simply just some trash that found it's way into the radiator, possibly from a junkyard or something?
The truck is running fine otherwise, but I'd sure like to know if this looks like it might be something I should be concerned about or not. Obviously, I'm going to be flushing and cleaning my cooling system in the near future. I've got the oxalic acid crystals on order now.
What is this thing?
Re: What is this thing?
Doesn't look familiar.
1967 F-100 4x4 custom cab.
- colnago
Must be those muffler bearings that everyone talks about. Not an option for my '67, and I'm not sure how they got in the radiator. ... unless you had one @#$%&* of a backfire through the carb!
Joseph
Joseph
What is it made out of...?
It looks vaguely like part of the shutoff valve on those funnels/tubes like you use for gear lube and such...
- jzjames
Looks like part of a hose or part of a spray nozzle on a hose.
>>Looks like part of a hose or part of a spray nozzle on a hose.>>
^^This.^^ I have one on my hose end sprayer. Identical. And, really, really old.
or, money.
or, money.
- Jacksdad
Makes sense - someone used a hose to fill the radiator and that fell off.
The spray hose nozzle is likely the correct answer, and it makes total sense. Good knowing it’s not something more critical.
Thanks for the ideas, ya’ll!
