Sanderson Shorty Headers
How easy is it to install the Sanderson shorty headers on an FE engine? I know long tubes can be a lot of work. Will the shorty's go in from the top? Will the motor have to jacked up or anything like that?
- Canonman67
Re: Sanderson Shorty Headers
I put mine on while the front clip was off so I'm going by what I see now. The passenger side should be pretty easy but the drivers side has the booster and master cylinder in the way.
- Mancar1
Put them on the 68's 390, (Camper Special), while motor was in the truck. All I had to do was change steering gears, (for clearance), from a 72 due to the bulge on the side of the 68's .
Had to go from a Bendix to a Saginaw. (think I got that right.
Had the headers on for a while now with no problems and I love them.
Keep on Trucking........John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Thanks guy's
Driver side from the bottom. Passenger side from the top. Went in great! Fit like a glove. Now to just get everything finished on the motor and fire it up.
- SeapineF37
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
