Bending ibeams for aligment
Fo-Mo-Co
Post by Fo-Mo-Co »
So I found a shop that has the equipment to bend the beams. How much drop can you correct with beam bending?
"We don't want tradition. We want to live in the present and the only history that is worth a tinker's dam is the history we make today."
Henry Ford
HIO Silver
Re: Bending ibeams for aligment
Post by HIO Silver »
About 2.25 inches... that's generally the distance between the I-beam and OE bumpstop... Prolly get up to 3 inches by cutting them down or going with shorter poly bumps..
Btw, get some good shocks.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
