Having trouble putting power steering pump on 67 f100 352 fe
Roger T
Post by Roger T »
I got a pump and bracket from a 390 fe car engine.When I try to put it on my oil filter is in the way any suggestions.thanks in advance
1972hiboy
Re: Having trouble putting power steering pump on 67 f100 352 fe
Post by 1972hiboy »
is your truck a 4x4? the 4x4 oil filter adapter hangs the filter in a different way as the two wheel drive trucks and cars do.
Rich
Dont eat yellow snow.....
cep62
Post by cep62 »
:wel:
Welcome to the site.
The FE oil filter housing bolts on and is different on some models, so it can be changed.
On mine I used a shorter filter , I think it;s from a chrysler V8 (318)?
and the V8 Mustang II also takes a short filter.
Roger T
Post by Roger T »
My truck is two wheel drive and I read the how to put power steering on two wheel drive trucks and it said I needed the truck filter mount that holds the filter horizontal and that's what I have.I thought about getting the oil filter relocator kit. Any thoughts?
cep62
Post by cep62 »
You can get a stock adapter that points the filter down , and it bolts on easy.
Mach428
Post by Mach428 »
Simply stated, you have the wrong PS bracket. Google or look on eBay for the right bracket. I'm a ourist at heart so I sways try to build them the right way.
You will be able to see the difference in the bracketry
