Hi
I am building up a 1974 f100 and have replaced the front suspension with a 2004 Crown Vic front end. I am based in South Africa, and therefore need to convert the left hand drive rack and pinion to right hand drive. Are there any other vehicles racks that are compatible e.g. Newer Ford Ranger etc. If not, do you have any suggestions.
rack and pinion swop
- 71PA_Highboy
Re: rack and pinion swop
I don't have a good answer for you, but a suggestion where to find a good answer...
Get online with some Australian car sites and work with them.
I think if you have the dimensions of the rack you will find a more experienced folks with a right hand drive solution.
Good Luck!
Good Luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
The folks at Flaming River make a right hand drive rack so give them a shout and see if it will work.
http://www.flamingriver.com/index.php/p ... 06/FR40023
Awesome, I will give them a shout asap.
