I upgraded to front discs with power steering from a 78 F100 to my 69 F100. I also used the 78 column in my transplant. I got all the steering components into place and went to bolt up the column when I noticed I had to pull the wheel up a few inches to get her to bolt in. Upon further inspection I noticed that the angle on the box looks different than the angle on the column. I have been searching the forums for someone else that may have had this issue without any luck. I'm not sure what I did wrong, can anyone help me out?
Thanks!!
Power Steering and Column Upgrade Questions
- themoldfords
Tim
____________________________________________________________________
'69 F100 240, 3 spd (used to be column shift), '05 F150 wheels, cougar buckets, Hurst floor shifter, '78 discs, power steering and column
"Your responsibility to be ready for the fight never ends" - James Yeager
- jimmy828
Re: Power Steering and Column Upgrade Questions
did you rob the power steering flange off the 78? It's a must to have along with the other parts. It's mounted to fire wall under hood. It will have the words "power steering" embossed on it. http://www.fordification.com/tech/image ... racket.jpg
- themoldfords
Yep. Got the complete column with the bracket. I'll snag some pictures this weekend.
Tim
- themoldfords
I was WRONG!!! I thought for sure I had robbed the P/S column bracket off the '78, but apparently I did not. I was lucky however, and snagged one at my local junk yard, along with these. Thanks for the help.
Tim
