I have been reading some post about different lenth springs on the front and do these trucks have a tendacy to site low on this side due to weight or something
That's what i was thinking, a shock really has no weight support values. Unless it's an air or spring shock.69NVF100 wrote:Most likely a spring issue as the shocks have nothing to really do with ride height unless the shock is froze up, just my.
Those are “Nitrogen or Gas Charged Shocks” they are pressurized with nitrogen gas, and are pretty standard now days for any good quality shock, but normal shocks (like came on our old trucks) don’t have this, they are just hydraulic shocks and will not effect the ride height any…fomocoguy wrote:Bad shocks will cause the front end to sit slightly lower than normal. They do have a slight amount of pressure in them. This is why when you install them you have to compress them some, then fight to get them in the right place before they stretch back out and mess you all up. I've been lieing on my back with a shaky arm trying to compress the darn things enough times to know this for sure!![]()
