checking one more time. someone must have had this issue
LUVMY69FORD250RANGER
Post by LUVMY69FORD250RANGER »
used to clink hard when i put it in park but otherwise drive fine. and it would shift had when going gear to gear, but recently it reved when i put it into drive when it was cold. then it seemed to do fine as long as i didnt let it sit too long , then i had to rev it to move again. all other gears are woking fine. its a c-6 automatic, 69 ranger, shop said, might need a over haul. u how those guys are, no repairs, just overhaul... i got a quote for 1200 for a complete rebuilt with torque conveter.
THANKS
Wes
Post by Wes »
shop is right seals and orings are worn out. When it warmed it would go into gear, or rev it up to make more pressure to over come the leakage.
Wes
67 F250 High boy
69 Bronco
seattle67
re: checking one more time. someone must have had this issu
Post by seattle67 »
We are assuming you checked the transmission fluid level?
Dan
oldschoolrods
Post by oldschoolrods »
My transmission started slipping real bad one time and thought it was gonna blow up before I got home so out of desperation I stopped and got some lucas transmission fix, and I was shocked the transmission shifted great. Worth a try if you weren't planning on a rebuild. :2cents:
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
ok guys got the kit, filter looked kinda dirty but fluid could still flow. we will see what new fluid will make it go into d gear again. i hope
THANKS
basketcase0302
Post by basketcase0302 »
Sounds like the torque convertor to me...
And $1200.00 is way too much to rebuild a C-6, suggest getting a second quote for the rebuild.
Or pull it yourself to save some bucks. :thup:
