took something off my steering column i shouldn't have..help
Hey guys, I was removing my steering column last night and when it came time for the wiring, i took the piece of the column off that the turn signal switch mounts to (thinking it plugged in back there and not by the floor) however now I can't get that little hub back on, there is 2 little square bolts that I think are supposed to slide over something but I can't figure out where. Please help thanks.
on edit: its an automatic column
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
re: took something off my steering column i shouldn't have..
are those bolts supposed to go into those little squares cut out on the metal tube?
- wt4speed#2
Re: re: took something off my steering column i shouldn't ha
Yupoldschoolrods wrote:are those bolts supposed to go into those little squares cut out on the metal tube?
- convincor
Yep, they just grab the edge.
I think what I did last time was start the nuts 1st, the put the hub in place. Easiest if the column is out of the truck and standing strait up. The square of the stud falls right in place, then tighten them up.
"Still Plays With Trucks"
Ignore the yellow arrow.
thanks keith thats exactly what i was looking for. Thanks to everyone that replied, maybe ill get back to it tommorow
well guys i think we got it back in, my dad came out and was able to help me out and we think we got it back in, we'll see if it comes flying off at me
thanks everyone for the replies
- flyboy2610
I feel your pain!
Those things are a PIA to get back together properly.
