is there a place where i can get another one of these plugs that plugs into the back of a door hinge light switch? when i was taking the plug off a peice of the plug got stuck in the switch .
where does the ac controls light go? does it go here? if not, what is this for? the wire is cut that goes to it also. where does the wire go?
oops, i had one more question. where do you think these wires went? the came off of one of my funky PO switches. i have no clue why they go to the glovebox. there are about 6 wires coming from the switch. the switch supposivly has to do with fuel tanks.
pic number 1 you needa new one from another harness. maybe a junkyard or in the parts wanted section.
pic 2 yes it goes there. look for the other end of the blue wire. maybe one of them from pic three. the switch in the glove box could be the hazard ligth switch. but in 71 the hazard light switch was moved to the lower drivers side dash so maybe not. it is a mystery until you follow the wires back to thier source.
Is there any switches lights or anything electrical to do with a glovebox. because i dont have a glovebox so maybe the blue wires go to the glovebox. ive tried tracing the blue wires, but WOW is it hard. there is so much black tape stuff wrapped around all the wires. ive actually started ripping it off and labeling wires though. cant wait until i find out what the wires and switches go to!
ok there was no switch in the glovebox im sorry. that square switch is for the military version of a rocket launcher. on the old trucks. no i dont know its somesort of po thing you just have to trace the wires in both directions to see what it goes to.
Actually, since you have a bench seat, when you press the button it flings the passenger door open and tilts the truck HARD to that side, which flings your passenger out the door!
Make sure you hang on TIGHT to that wheel, man! You could be flung out too!
well then where the oil slicks? oh its that other PO switch on the dash. i think i need to refill them with oil because nothing happens when i flick the switch.
i took the whole unit out because it was too hard to get to parts.
here is a pic of the cut wire with a broken bulb on the other end. ( i dropped the bulb as i was getting the camera )
a pic of them together
now im confused. i have a wire with a bulb on the end of it that is dangling from under my glove box area. i thought it was supposed to go to the ac controls but it obviously doesnt if there is allready one in there. so where does the other bulb go? radio which i dont have maybe?
i found it. the light is just on the end of a wire dangling under the glove box area/ac controls area, and has a little rusted clip on the wire as if it is suppose to clamp on to something. i could try tracing it but every wire in my truck leads to being covered with electrical tape with 100 other wires.
