converting 5x5.5" to 5x135mm
lightning_msd
Post by lightning_msd »
i would like to convert my 67 from 5x5.5 to 135mm, is this possible? has anyone ever thought of it or done it? i would like to do it without installing a IFS on the front, the rear shouldnt be too hard, i can probably find the axles, along with that i want disc brakes. would anyone know of any conversion kits for this application? :?
wheel adapters maybe.
lightning_msd
re: converting 5x5.5" to 5x135mm
is there anyone that does these wheel adapters?
ezernut9mm
Post by ezernut9mm »
wheel adapters are pretty common and should be available at any of the big discount tire and wheel stores like discount tire direct or tire rack. your local tire shop should be able to get them as well. if you already have some wheels in mind they can be redrilled to the 5x5.5.
ezernut9mm
check out this site. http://www.wheeladapter.com/home.asp they will give you a quote over the internet too.
lightning_msd
thanks ezer, the wheels that i have are second gen. lightning wheels, so there 135mm, i thought (never good at math) 135mm was 5.5" until recently i found out i was wrong. i dont think i can get them redrilled, if i can where can i do that and how costly?
19674x4
Post by 19674x4 »
ive' done the opposite on our race car. just filled the holes by welding beads, and hardened it, then re-drilled them. works fine, and you can't tell
My Photo Album
