I have a 390 that I am swapping into my 71 F100. I scored a T18 from a '73 F250 along with crossmembers and bellhousing. My current setup is a 240 with the three speed on the coulmn. What parts if any am I leaving out? I have
The engine
bellhousing
clutch assembly
transmission
motor mounts
crossmember
bigger coil springs from a 390 truck
driveshaft
Any thoughts or suggestions would be appreciated. What problems do you
anticipate? This will be my first engine swap.
Few driveline questions...
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
- splavin90
re: Few driveline questions...
only thing i can think of is-
V8 gas pedal, and linkages that bolt to manifold
you may have to modify the frame for the tranny crossmember
69 F100 81' 302 / 73' fmx
- fourtss
your cross member may not work however before yopu invest in another one be sure to turn the crossmember 180 degrees it might work then, when I took my 435 out and put my c6 in all I had to do is rotate my crossmember 180 degrees taadaa perfect fit
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
2003 ford escape
Thanks for the info...didn't even think of the gas pedal
1989 Ford F150
1989 Ford F150
I got the crossmember from the donor truck
1989 Ford F150
1989 Ford F150
- bobbyinpd
Fab your own throttle linkage like I did from the pedal to the carb with 2 heim joints and a piece of bar stock, no need for the screwy factory linkage CF!!!
1996 F350 4 Door Dually Long Bed Power Stroke Diesel - K&N FIPK Intake, MBRP 4" Straight Exhaust, Diesel Turbo Lifesaver Turbo Timer, BriteBox.
1990 Escort 1.9L Stock
1958 Bel Air 4 door - FOR SALE
1975ish Camaro Autocross Car
1973 Camaro RS awaiting cage,backhalf, and 498 BBC
1969 El Camino - Wife's car
2004 Carson Trailer-to haul the goods!
www.bobby77.com
www.bobby77.com
- two-bit
Don't forget to move your engine stands on the cross member. If i remember right the sixes are different from the V-8's. You will need to move them. Otherwise you'll never get that 390 in the mounts.
I don't remember to which position, maybe someone else can chime in and let you know.
- flyboy2610
Re: re: Few driveline questions...
I have one if your interested.mjhaltom wrote:Thanks for the info...didn't even think of the gas pedal
