I need to find out the proper routing for the heater hoses on my 72 f-100 with a 302 engine
I hope I have right forum if not I am sorry
thanks
Bob B
heater hose routing
Re: heater hose routing
Heater hose from water pump to heater core, out of heater core to carburetor heat plate (if it has one) back to manifold
Heater hose from water pump to water valve, to heater core, out of heater core to carburetor heat plate (if it has one) back to manifold
that is how mine is hooked up but heat still comes in cab it not nice on a summer day it is like the heat
will not shut off
thanks
Bob B
will not shut off
thanks
Bob B
Check the heater water valve. Make sure it is closing fully. There is a ball type fixture that may be seized or broken. This is what the temperature lever is connected to
Also, when you move the upper lever to off, there is a door inside the heater box that should close. Check your cables
- colnago
My water valve was rusted off completely when I got my truck. Not surprised on a 50-year-old truck. It was a pretty easy/cheap fix.
I put a new heater valve in I thought that would be it I will have to check to be sure that it closes all the way
I been thinking of putting shut off valves in the hoses hoping that will cure the problem
thanks
Bob B
thanks
Bob B
