heater hose routing
BobB
heater hose routing
Post by BobB »
I need to find out the proper routing for the heater hoses on my 72 f-100 with a 302 engine
I hope I have right forum if not I am sorry
thanks
Bob B
Mach428
Re: heater hose routing
Post by Mach428 »
Heater hose from water pump to heater core, out of heater core to carburetor heat plate (if it has one) back to manifold
Mach428
Post by Mach428 »
Heater hose from water pump to water valve, to heater core, out of heater core to carburetor heat plate (if it has one) back to manifold
BobB
Post by BobB »
that is how mine is hooked up but heat still comes in cab it not nice on a summer day it is like the heat
will not shut off
thanks
Bob B
Mach428
Post by Mach428 »
Check the heater water valve. Make sure it is closing fully. There is a ball type fixture that may be seized or broken. This is what the temperature lever is connected to
Also, when you move the upper lever to off, there is a door inside the heater box that should close. Check your cables
colnago
Post by colnago »
My water valve was rusted off completely when I got my truck. Not surprised on a 50-year-old truck. It was a pretty easy/cheap fix.
Joseph
BobB
Post by BobB »
I put a new heater valve in I thought that would be it I will have to check to be sure that it closes all the way
I been thinking of putting shut off valves in the hoses hoping that will cure the problem
thanks
Bob B
