Ford 300 Engine Replacement
tevail
Post by tevail »
I have a 1965 Ford F-250 with the original Ford 300 L6. The motor is beyond repair, can I replace it easily with a 1981 300, carbureted engine? Are all the bolt holes and dimensions the same? Thanks, Tim
jzjames
Re: Ford 300 Engine Replacement
Post by jzjames »
I'm pretty sure it is an easy drop in.
Even a fuel injected 300-six.
Have you checked out this site for the inline-6?
https://fordsix.com//viewforum.php?f=2& ... b2709eb49e
ThinLizzy13
Post by ThinLizzy13 »
I did this exact thing to my 66 F250. I found a carbureted 300 out of an 80's pickup. I used the intake and carb setup that was on my '66's busted engine and put it on the "new" engine. A local shop did the actual install. I talked to the mechanic afterwards and he told me it was a direct bolt in.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
