Rag joint
tynall44
Rag joint
Post by tynall44 »
Does anybody have a good tag joint ???
wndsofchng06
Re: Rag joint
Post by wndsofchng06 »
This is something I would buy new....
hillcountryflt
Re: Rag joint
Post by hillcountryflt »
Yep, it's one of those Dorman HELP products found at O Reilley's, etc. or at Amazon.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
vossy
Re: Rag joint
Post by vossy »
I did mine with one of those doorman sets too.. The bolts that came with the doorman kit were too short (for this short tempered novice wrencher) to use the locking washers, well I'm sure I could have got them to work, but it was very frustrating when the lock washer gives you sliver of a thread to hand thread the nut on.. So, I ended up using some bolts I had, that were the same size just a little longer, and I think I used one bolt from the removed rag joint... My recommendation would be to get slightly longer (maybe 1/4" longer) bolts from the hardware store than the bolts that come along with the doorman kit, before you head home to replace the rag joint. It was very frustrating dropping that nut 35x before I finally got different bolts...
Re: Rag joint
:lol: I bought one of those help rag joints. It tore when i installed it. It would be stronger to cut up a tire than use one of those again.
AZf100
Re: Rag joint
Post by AZf100 »
I ordered a brand new one from Advanced Auto for 35.00
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
