new f250, quick questions!
Andre69f250
Post by Andre69f250 »
Just bought a 69 f250 with what i was told has a stock 302 and c6 out of a mustang. the car used to be a stick shift i believe, but is now on the column and automatic. the column shifter is SLOPPY, pretty out of whack, goes in gear but, you got to mess with it... how do i tighten up the column shifting linkage and all?
Also i am going to drain the tranny pan and change the fluid and filter. This car takes the AT type F correct? And if im going to just drain the bottom pan how much atf do i need? 4 quarts?
also how do i identify its a c6?
thanks!!
HIO Silver
Re: new f250, quick questions!
Post by HIO Silver »
Please stop calling it a "car". It's a friggin' TRUCK.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
tnlprt
Post by tnlprt »
If the trans came from a mustang it was probably a floor shift model which has a different shift lever on the trans than a column shift trans has
You need to crawl under the truck and see which lever it has
If it has the floor shift lever the column shifter may be cobbled together
Type F trans fluid is more than likely the correct fluid
most early trans dip sticks will say what type of fluid to use
buy between 4 to 6 quarts as it will not go bad in a sealed container
The left over fluid can be used in the power steering
Andre69f250
Yes I know!! Sorry! I will refer to it as a truck!!! My bad.
Thanks for the replies! I will go an check it out tomorrow and take some photos
Mancar1
Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Post by Mancar1 »
Your truck, call it want ya want.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
6Delta
Post by 6Delta »
Andre69f250 wrote:Yes I know!! Sorry! I will refer to it as a truck!!! My bad.
No worries. Where/when I grew up a "truck" was something you could haul a pickup in. Now city boys call anything with a bed a truck. Its all good. At least you're not driving a Chevy. :wel:
No Brain - No Pain
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
Mancar1
Post by Mancar1 »
How true, a pickup was just that, a pickup. A truck was a TRUCK. :thup: :lol:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
