New addtion to 72 F100 interior
03svtsnakevert
Re: New addtion to 72 F100 interior
Post by 03svtsnakevert »
JMcTurnan wrote:I found it, but extremely expensive. Did it hook right up?
Yeah it was not bad at all...took about 4 hrs
JMcTurnan
Post by JMcTurnan »
Yea, I doubt I'd ever get one because of the price. But it looks damn good man. If I would end up getting one id wait ill my interior is painted so I don't have to double wire. Either that or Id make hook ups. But it looks good man. How does the spedo hook up, I would think you would have trouble? From a manual one?
03svtsnakevert
JMcTurnan wrote:Yea, I doubt I'd ever get one because of the price. But it looks damn good man. If I would end up getting one id wait ill my interior is painted so I don't have to double wire. Either that or Id make hook ups. But it looks good man. How does the spedo hook up, I would think you would have trouble? From a manual one?
Well, I have already sanded and painted the dash...just have to paint the back side of the cab now...Dakota sends a nice sender for the transmission that has a little part that your stock speedo gear fits on and they have a small inner square piece of cable that goes into that and and electrical sender that screws over that so the gear spins the square cable piece which in turn spins the electrical sender
JMcTurnan
Post by JMcTurnan »
Ah, gotcha. Thanks
dcbullet
Post by dcbullet »
Hey, volt meter. that's a nice upgrade.
dantheman71
Post by dantheman71 »
Ok now I am jealous. I also spent the big bucks and bought the same set-up. Only my truck is in pieces right now so the best I could do is set it up on the bench :cry:
I think it is a very cool set up overall and I am glad I made the purchase. The one thing I don't like is how the original hole in the cluster where the odometer was does not have anything digital behind it. I also bought the electronic gear position sensor and was hoping that it would display my gear position at all times in that hole while driving. I guess that is what happens when I don't do my homework.
Cool project, keep up the great work!!
:thup:
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
03svtsnakevert
dantheman71 wrote:Ok now I am jealous. I also spent the big bucks and bought the same set-up. Only my truck is in pieces right now so the best I could do is set it up on the bench :cry:
:thup:
Thanks! Yeah,I wondered the same thing...Initially I had the digital cluster behind the bezel without the black middle piece...It did not look well and did not screw in well, so I added the black piece back...Let me know how hard the gear indicator is to install.
Thanks!
red403
Post by red403 »
So how does it hook up? The 72 has the printed circuit on the back correct? What about installing one in a 67 that has the plug and no printed curcuit?
03svtsnakevert
red403 wrote:So how does it hook up? The 72 has the printed circuit on the back correct? What about installing one in a 67 that has the plug and no printed curcuit?
It will go right in...all you have to do is figure out what wires are you turn signals, high beam indicator and any other indicator lights you want to use...no problems
72-F100-4V
Post by 72-F100-4V »
So how has your dash been since you installed it? how well can you see it during the day? How open is the area where the odometer used to go on the back side? I think that would be a great place for something I have in mind. Ive bought this and cant wait to get home and play with it.
