Driveshaft questions
customcrewcab
re: Driveshaft questions
Post by customcrewcab »
my drivshaft is 74 inches long and its a crewcab. i just ordered it and you measure from the end of the output shaft to the flat part on the yoke with the u jount out and the caps off.
customcrewcab
spartman
Post by spartman »
Okay got a chance to measure the distance on my truck.
Looks like its 65 inches from yolk to yolk.
