8-5 lug
ranger7489
8-5 lug
Post by ranger7489 »
Do they make things you can bolt onto 5lugs to make it into a 8lug? Like a conversion kit. Just bolt it onto the 5lug
72 F-100 302 V8, bf goodrich a/t's, true duals, magnaflow mufflers, undergoing serious body work, K&N air filter, 2bbl carb, stock suspension, steering stablizers, 3:73's
67highboy
re: 8-5 lug
Post by 67highboy »
:hmm: Not that I know of
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
ranger7489
Is there a way i could put 8 lug (f350 or f250) rotors and lugs and everything on my 72?
72hiboy4x4
Post by 72hiboy4x4 »
do you want to dually the front and rear?
A 3/4 ton rear axle should bolt right into your truck. Dually wheels should fit right onto that. I can double check that this weekend if you like.
I kinda think that if you used '73-up F250 parts (the entire front I-beams, I mean), they might bolt right into the front, and give you disc brakes to boot.
ranger7489
Well my friend has 99F350 wheels and tires (31"s) and I would also like it an 8 lug just for convienance, its alot easier(aroud here anyways) to find 8lugs other then 5 because allmost everyone drives newer model big trucks, like 3500's and F250's and 350's. I know the lug patern isent the same for 3500's, just saying. I also have the conversion kit to turn a 8 lug into a dually. Its been sitting in my garage for awhile with no use to it.
One more question. I dont know the year, but the 3/4 ton F250's...When they had 5lugs those few years. Do they have the same lug patern as my truck?
67heavystepside
re: 8-5 lug
Post by 67heavystepside »
are you talking about the 1997 or98 f250, if so they wern't considered f250superduty, they were actually f250 light duty with 7 lugs, and they had f150 heavyduty that year in 7lug. standard duty 150 was 5 lug. but as for lug pattern size , not sure.
ranger7489
Im not exactly sure. I will have to ask him later tonight. I think it was a 150, anyways, it was an older model, maybe late 80's.
flyboy2610
re: 8-5 lug
Post by flyboy2610 »
If you want to use 8 lug wheels up front you are going to have to go with F250 spindles. I don't remember if the I-beams are the same or not, but I would just swap the whole assembly in.
An F250-F350 rear end will bolt right up.
Galaxie64
Re: re: 8-5 lug
Post by Galaxie64 »
67heavystepside wrote:are you talking about the 1997 or98 f250, if so they wern't considered f250superduty, they were actually f250 light duty with 7 lugs, and they had f150 heavyduty that year in 7lug. standard duty 150 was 5 lug. but as for lug pattern size , not sure.
I'll try to straighten it out. As most know the "pre" Superduties ended in '97 this was the boxy '92-'97 style. There were no F350's or Superduties for that matter made in '98. '99 brought about the Superduty name and the new body style. Now Ford made a F250LD (low Duty) that looked identical to the '97-'98 F150 but it had 7 lug rims and better torsion bars. After '98 They changed the F250LD to a 7700 F150, because it had 7700 GVW capability. The only change was really the nameplate the rims stayed 7 lug as well as the weight ratings remaining.
My understanding is the mid 80's 8 lugs will fit on the bumpside hubs but I still haven't nailed this down for sure, I also think the '97+ F150 135mm 5 lugs may also fit on the bumpside F150's. One other thing, the '97-'98 F150 had 12mm lugs where as the '99-'03s had 14mm lugs and of course were all lugcentric not hub like our bumpsides.
Maybe we can straigten out what Ford rims will fit on my '72 8 lug hubs, I get confused on whether the newer '80's+ will work or not. I think I have an early 80's rim somewhere I should just try and see. I also have some '92 and '93 rims I could try.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
doc
Post by doc »
'97-down 8-lugs are 8x6.5
'99-up Super Duty trucks are 8x170mm
I ran '97 F-250 aluminum wheels on my '78F-250 w/ no problems @ all.....it having the big twin-piston calipers.
Clarko
Re: re: 8-5 lug
Post by Clarko »
Galaxie64 wrote:I'll try to straighten it out. As most know the "pre" Superduties ended in '97 this was the boxy '92-'97 style. There were no F350's or Superduties for that matter made in '98.
Yes there were but it was a short production run as the 99 model year started early.
Galaxie64 wrote:'99 brought about the Superduty name and the new body style. Now Ford made a F250LD (low Duty) that looked identical to the '97-'98 F150 but it had 7 lug rims and better torsion bars. After '98 They changed the F250LD to a 7700 F150, because it had 7700 GVW capability. The only change was really the nameplate the rims stayed 7 lug as well as the weight ratings remaining.
That was the F-250 Light Duty and the older body was called the F-250 Heavy Duty.
Galaxie64 wrote:My understanding is the mid 80's 8 lugs will fit on the bumpside hubs but I still haven't nailed this down for sure.
Yep, all 8-lug F-250s and F-350s through the end of the 1992-1998 body style.
Galaxie64 wrote:I also think the '97+ F150 135mm 5 lugs may also fit on the bumpside F150's. One other thing, the '97-'98 F150 had 12mm lugs where as the '99-'03s had 14mm lugs and of course were all lugcentric not hub like our bumpsides.
Nope, 5.5 inches equals about 140mm. It won't work as the 97-03 wheels are off by about 5mm too small.
Galaxie64 wrote:Maybe we can straigten out what Ford rims will fit on my '72 8 lug hubs, I get confused on whether the newer '80's+ will work or not. I think I have an early 80's rim somewhere I should just try and see. I also have some '92 and '93 rims I could try.
Yes, read above.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
rjewkes
Post by rjewkes »
I know clear upto 92 if it had 5x5.5" lug pattern the rims will mount on anything with 5x5.5 unless you have the smaller hub on the newer one. They made two sizes of hubs in the 80's i beleive.
fuelly.com
Clarko
Post by Clarko »
Not on the trucks, they didn't (at least in my travels on the 2WD). The 4x4s for sure didn't change through 96.
Only on the cars they did.
5x5.5" was used on the F-150s clear through 96.
BTW: Econoline vans still use the 5x5.5" lug pattern on the E-150s and the E-250/E-350 still use the 8x6.5" lug pattern to this day.
06 Econoline wheels fit on Fullsize Broncos (all of which were 4x4) so they will fit on our Bumpsides, for sure.
Brian
67heavystepside
re: 8-5 lug
the newer 8 lug steel wheels mid 90's fit on my 67 f250 with front drum. that is what i used to convert to 16" then i went to the white spoke wheels.
