In case you are trying to rip yours out and wonder how it is put together.
First there is no nut at the bottom because the bottom piece is threaded. This is helpful in removal because once you loosen the bolt up almost all the way you can hammer it from the inside using a socket extension and it will pop right off.
Fyi pix of factory rear cab bushing
- jzjames
