68 f100 restoration.
Fordkid68
Post by Fordkid68 »
Hello everyone, I decided to start a thread about my 68 F100, This is my first truck, and I am restoring it to be my daily driver. The deadline to complete it is August 2021, hopefully it will be on the road by then. Here it is the day we got it home! Yeehaw!
No holes in the bed!
Stay tuned it is going to be a wild ride!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
Fordkid68
Re: 68 f100 restoration.
Post by Fordkid68 »
I started this thread late so I will post the progress so far. I was told this was a running 390 but it turned out to be a clogged up 360.
Decided to build a 351w, and put in a toploader 4-speed.
Tried to see if the original seat would clean up, but it is very faded.
This is the grille that came with the truck. unfortunately it is a '71 and not the original '68.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
started to tear the front end down.
Removed the front end!
This is the original paint under the dash pad, it was a custom ordered color.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Got the front clip off and engine removed.
Starting to patch the floors.
Had to rebuild the lip on the door jam. As you can see I am an amateur welder!
The driver side was worse than the passenger floor so I am going to order a floor pan.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Got the dash torn apart, along with the heater.
Removed the emergency brake pedal and made a return spring.
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Had to put a small patch on the firewall lip. Not pretty but it works!
Got the bed off.
This is how the truck sits now. Got the brake lines, and hoses off, fuel lines are out, and shocks removed. once the cab comes off, the frame is ready for paint.
Adam
My first truck,
^^Build Thread^^
Venomous duck
Post by Venomous duck »
Looks like you have a nice project going, cant wait to see more.
Fordkid68
Post by Fordkid68 »
Got the brakes torn apart. The previous owner did the brakes, but did not do the rear left brakes! Although the drum has some chips out of it, so my guess is he tried to get it off and chipped it, and could not get it off, so gave up!
So now I had to order parts to do the rear brakes that I was told were redone! but at least both fronts were done!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Got some work done on the drivers floor today! got the old floor cut out, and started fitting in the new one from DC. Now I just have to final fit it, and then weld it in.
Adam
My first truck,
^^Build Thread^^
LeoZelig
Post by LeoZelig »
Hey Fordkid68! Thanks for sharing in-progress photos and details on your restoration, looking good!
I'm eager to hear about your experience with the DC floor pan - let me know your impressions on the fit and quality, please. Will you install the whole pan or just enough to replace the rot? I'm probably going to need to do the same on my passenger side floor.
Keep up the great work!
Chris
Project Thread: http://fordification.com/forum/viewtopi ... 22&t=96617
1969 F100 - Roy
SWB
3-on-the-floor and I hope to return it to 3-on-the-tree
360
49k on odometer... actual? Anyone's guess :)
Fordkid68
Post by Fordkid68 »
Thanks LeoZelig! I am only using enough floor pan to cover the rot, because then I do not have to recut any of the factory holes near the pedals, like clutch linkage, or e-brake holes.
The pan does not fit perfectly so it requires some trimming to make it fit. But overall it is not too bad, but unfortunately it is made in Taiwan, which I did not expect from DC. It does seem to be a decent quality though, and it will not be exact because it is made to fit dentsides also. So it has some extra beadrolls, that bumpsides do not have.
I hope this helps. Good luck!
Adam
My first truck,
^^Build Thread^^
LeoZelig
Post by LeoZelig »
Fordkid68 wrote:it is made in Taiwan, which I did not expect from DC
That is surprising, Fordkid68 - makes me wonder if I should just get the El Cheapo floor pans from Parts Geek, instead.
I don't mind the bead rolls being different - but that's good to know. That could be a factor for some people.
Can't wait to see your update on the floor repair, especially.
Take care!
Chris
1969 F100 - Roy
SWB
360
bellamor
Post by bellamor »
It seems like this build will keep you busy in the long run. Make sure you keep us posted with the restoration progress. :D
Fordkid68
Post by Fordkid68 »
Thanks guys!
Got the pan welded in yesterday! It went in good, with no problems. I punched holes in it along the door sills to spot weld. and drilled a couple of holes to weld to the back of the cab mount like it was originally. And along the door sill edge I ran a solid bead to make it really strong.
The red spray on it is self etching weld- thru primer. I am using it to hopefully prevent surface rust from starting between the panels.
Here it is cleaned up and ready to be welded in.
Got it tacked in.
Ground the welds.
It came out pretty good considering this is the first time I ever replaced an entire floor pan!
Thanks for all the support!
Adam
My first truck,
^^Build Thread^^
Fordkid68
Post by Fordkid68 »
Here is the floor with more primer on it. The edges are noticeable but I am going to put carpet in anyway.
I also removed the back window. The seals were pretty bad and were very ugly, so I am replacing them. The window came out very easy, I duct taped the window to the cab so it wouldn't fall out, then I just used a utility knife to cut the seal from the inside, and popped the the glass out. It was very easy and only took about 15 minutes.
IMG_7134.JPG[/attachment[attachment=0]IMG_7142.JPG
Adam
My first truck,
^^Build Thread^^
