Mystery Part ID
69-er
Mystery Part ID
Post by 69-er »
Here's a mystery part that came out of the box of parts for the 71 F100 360 build.
Can anyone ID this for me?
Re: Mystery Part ID
That is the throttle return spring bracket. Mounts to the intake manifold at the coil mount. That one looks like it has been beat flat, mine is angled from the bolt along the line visible in yours, corresponds to the lip on manifold boss.
69-er
Re: Mystery Part ID
Post by 69-er »
I think I see the bend area you are talking about. Is it bent at the line I have drawn? How many degrees do you think?
I'll line it up on the manifold to see if I can make sense of it.
69-er
Re: Mystery Part ID
Post by 69-er »
I haven't tried fitting the bracket to the intake yet but I found this online... It's flat like mine.
Re: Mystery Part ID
I’ll try to get you a picture today.
69-er
Re: Mystery Part ID
Post by 69-er »
I saw #9741 in the diagram section but it's not quite like mine.
69-er
Re: Mystery Part ID
Post by 69-er »
I test fit it on the intake. I think I see what you were saying about it matching the lip on the intake. The corner should be bent up?
Re: Mystery Part ID
Here you go...
More later
