Stage 8 Header Bolts?
colnago
Post by colnago »
Has anyone used Stage 8 Header Bolts? They incorporate this funky clip so the exhaust bolts can't back out once you torque them down. I'm fighting an exhaust leak, and wondering if it's worth the $60+ for these bolts.
Joseph
1972hiboy
Re: Stage 8 Header Bolts?
Post by 1972hiboy »
you still have manifolds or headers on your truck?
Rich
Dont eat yellow snow.....
N2deep
Post by N2deep »
No experience with the bolts you mentioned, however, if you use good quality bolts (grade 8’s or better) with a proper lock washer and proper torque values, they seem to hold for me. Also make sure you lubricate the bolts with a good high temperature never sneeze like N7000. Best of luck
I have some (in fact the bolts may be what is on my truck) but the locks were too short to do any good on the top IIRC... been a while...
Ranchero50
Post by Ranchero50 »
Pick up some Nord-Lock washers and don't use paper gaskets.
Eric46
Post by Eric46 »
I have them on a couple of engines and they work fine. I also like them for the 1" under head length and 12pt head. If you're using them on a FE make sure you get the set for a big block as the "tear drop" locks in the small block kit will be too short.
Eric
1970 F-250 4x4
colnago
Post by colnago »
1972hiboy wrote:you still have manifolds or headers on your truck?
Still have manifolds, but I'm going to try to put Sanderson Shorties this year.
Joseph
colnago
Post by colnago »
Ranchero50 wrote:Pick up some Nord-Lock washers and don't use paper gaskets.
I used the Nord-Lock washers when I converted the front end from drum to disc brakes. The guy at Fastenal thought I was nuts! :lol: Kinda pricey, but cheaper than the Stage 8.
Joseph
Lee
Post by Lee »
While on the subject,... I fought exhaust manifold leaks with my headers for years....constantly having to change the composite gaskets... finally solved the leak problem by using the thick copper gaskets (which are re-usable)... no more leaks!!!!
Lee
