i have a 1967 f100 with a 302 all stock, was wondering the best fit for the fan shroud doesn't need to be a 67' anything close with minor adjustments is find, after market is ok , i just have no idea where to start. D. Carpenter are sold out on the 67, any help would be much appreciated thanks
fan shroud? what year fits or any year my 67'
Re: fan shroud? what year fits or any year my 67'
Are you sure it's a 302 because that wasn't offered in a bump until 1969..........
1997 Honda CBR 900RR
probably not stock as numbers matching or year correct, just basic 302, have no idea of the year...i was told a 71'
but if you know of a good shroud to get for the 67' let me know thanks
Consider an electric fan. Shroud is built in. And no exposed, whirling nightmare to injure yerself or damage tools on. Slightly increased mpg's. Quieter operation so you can hear the radio. Or have a conversation with a passenger without yelling.
If the cooling system is in good shape, I've found that a fan isn't needed as long as the vehicle is moving at least 15-20 mph.
Our trucks have a large frontal area. This helps alot with natural airflow to the radiator. Unlike modern, more aerodynamic vehicles.
Mr Ian, I agree with Mr Ren about an electric fan with a shroud.
You can get one from the junk yard, just have to look at the shape of the shroud.
I believe some have used Ford Taurus fans and shroud, not sure what years.
You can also get a Flex-O-Lite Black Magic Extreme .
I have one on my 93 5.0 Mustang and I put one on my 72 truck as well , it has a 429 but I don't see any reason it would not work on your truck as well.
It comes with everything needed to hook it up including the shroud, electric fan, wiring, adjustable thermostat switch control.
I adjusted switch to come on at 195*.
It is very easy to install.
Check before you order but I THINK it is model 185 ( I am not sure if that is the correct #) , it is the one for 1979-1993 Mustang, 15" S blade fan, 3,300cfm.
My fan only comes on if I sit in traffic or long periods of idling or pulling a heavy load.
Good luck which ever way you decide to go.
https://youtu.be/0vRZFH_r5q0
https://www.flex-a-lite.com/direct-fit- ... stang.html
thanks for the heads up I'm looking in to the tips,aswesome thanks again
