The rear panels are available for repair. The front side of the rear cab corners are not available as repair parts.
What is the repair procedure for these panels?
Make them yourself?
Just weld in a flat repair panel?
[image]441[/image][image]442[/image]
I will look into getting some made.
Any interest in anyone needing some replacement panels?
I’m thinking of getting a long sheet made of the correct form and just cut off the length. Then just pinch flat at the bottom spot weld.
Cab corner repair
- BobbyFord
Re: Cab corner repair
Fab them yourself. I'll be tackling this soon.
- Ranchero50
Ditto or find a donor and cut them out. That's the route I took. Old box trucks are good candidates.
Fab it up from a good section of a box floor.
or, money.
or, money.
- Manny
This is one i am gonna have to handle as well... Does bed floor fix it well??? actually look right?
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- austin
I fabbed mine out of a sheet of 12 gauge iirc and I just used basic hand tools, it was good enough for the girls I go with
