Brake Lines
Brake Lines
This part where brake lines come from wheel cylinders and has the vent tube as well had the line you see coming from the master and its all dry rotted. It isn't a screw in like the brake lines from wheel cylinders, it had the clamped hose as you see and it's dry rotted, how do I fix this dry rotted tube, does the whole part come out of the axle shaft or what.
Re: Brake Lines
Unscrew the axle vent fitting and the flex hose comes right off.
1967 F-100 4x4 custom cab.
Re: Brake Lines
Okay busboy so that was simple enough
, but that fitting with the hose connected to it, what is the part name that I am looking for to replace that? Thanks again for my lack of intelligence with this one, it's been a long day getting dash out with utterly scraped up hands and arms, no patience left I guess on the this one.
- sargentrs
Re: Brake Lines
- Ron_Hall
Re: Brake Lines
Hey Preacher, If you haven't already got it this might help..massillon preacher wrote:Okay busboy so that was simple enough, but that fitting with the hose connected to it, what is the part name that I am looking for to replace that? Thanks again for my lack of intelligence with this one, it's been a long day getting dash out with utterly scraped up hands and arms, no patience left I guess on the this one.
https://www.summitracing.com/nv/parts/d ... /overview/
Ron
One owner...
One owner...
