How easy would it be to cut the front off an 81-86 Ford F-150 frame and weld it to the back half (Cab and back) 68 frame? I know the frame widths might be different but can it be done ??
Thanks, Scott
Front Frame Swap
- Manny
Re: Front Frame Swap
Well anything can be done. My question is whats your goal here by doing this I view the twin i beam of the early years is superior to the 80-96 different length beams. Just curious what your trying to get to here
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- HIO Silver
Sure. I can do that....Pointman wrote:How easy would it be to cut the front off an 81-86 Ford F-150 frame and weld it to the back half (Cab and back) 68 frame? I know the frame widths might be different but can it be done ??
Thanks, Scott
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
I was thinking that the 80s disc brakes wouldn't bolt on the 68 suspension and I would also have the power steering in place. Maybe too much work for the trouble but just checking my options.Manny wrote:Well anything can be done. My question is whats your goal here by doing this I view the twin i beam of the early years is superior to the 80-96 different length beams. Just curious what your trying to get to here![]()
Thanks, Scott
- colnago
Why don't you just get the disc brake components for a '68? I got the brackets and dust shields from a junk yard, and new/rebuilt calipers, rotors, hardware, etc. It all bolted up to my existing axles/suspension/etc.
Joseph
Joseph
