does anyone make a front coilspring with a 2" lift for a 1972 2wd?
thanks matt
2wd bumpside front coil lift?
- HIO Silver
Re: 2wd bumpside front coil lift?
Autofab is the only game in town in lifting a 2wd but there is more to it than just taller coils.
i saw on ebay someone is selling a setup with extended shock and a coil spacer that lifts the front 2", anyone use that? is that safe?
- Manny
Beware on the spacers. Just adding spacers throws the old school twin i beams into a massive positive camber and caster situation. To lift and ibeam truck properly you need to extend the pivot brackets and the radius arm brackets to match how high you lift it. Autofab i you look has custom beams to get your alignment right with the lift. Spacers can be used safely if the are the better aluminum ones but you will need other components to get the alignment right.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
thanks, good info,
what other components do i need to do it right with spacers?, i just want to get the truck level, lift the front maybe 2", maybe an inch higher than the rear and use 32" tires
thanks matt
thanks matt
Eaton Detroit Spring will make you a +2" coil-
https://www.eatondetroitspring.com/orde ... ts-lookup/#
