Hi everybody.. Does anyone know how I remove these chrome trim pieces?
Thanks
Ron
Drip rail trim
- Ron_Hall
Drip rail trim
One owner...
One owner...
- TNIceWolf
Re: Drip rail trim
Old school bottle opener. Apparently it peels off like a beer cap. All of the trim I purchased from members here that you pictured was removed and sent to me that way. Seems to be the way to go if you go slow and use care and thought.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
Re: Drip rail trim
- Ron_Hall
Re: Drip rail trim
Thanks guys, it WORKS!!!
One owner...
One owner...
- tnab1970
Re: Drip rail trim
can also remove with two pinch bars very easily when found at wrecking yard. First one upside down on the glass, second used correctly just under the edge of the trim. If this trim is not on your "wrecking yard grab" list it should be. It can be very difficult to locate.
