BRAKE PARTS NOT MADE IN CHINA
radioactivelarry
Post by radioactivelarry »
Where can I purchase brake parts for drum brakes not made in China. I'm doing a complete brake job from the master all the way down to the wheel cylinders including rubber brake hoses and shoes.
No one has any brake parts not made in China. Called all the big chain parts stores including NAPA
My local hot rod/speed shop checked sources for me and all the MADE IN USA PARTS were no longer available!I could send out my shoes to be relined but everything else is China sourced including master and wheel cylinder kits.
Rubber hoses are also made in China.
Anyone used this Chinese stuff?? Did it work OK, was it reliable and did the parts fit?
I don't want to use Chinese parts on m Classic F-100 :nono:
Democracy is two Wolves and a Lamb voting on what to have for lunch. Liberty is a well armed Lamb.
Ben Franklin.
My Motto: I wish I had less to do, more time to do it in and got paid more for not getting it done.
:drive:
ThinLizzy13
Re: BRAKE PARTS NOT MADE IN CHINA
Post by ThinLizzy13 »
I recently redid my brakes - drums, shoes, soft lines, wheel cylinders. It was all made overseas stuff, but fit as it should and functions properly.
If you want made in US parts you could look for NOS parts on eBay/craigslist, but it will probably be pretty pricey.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
radioactivelarry
ThinLizzy13 wrote:I recently redid my brakes - drums, shoes, soft lines, wheel cylinders. It was all made overseas stuff, but fit as it should and functions properly.
Using NAPA or O'Reilly parts minus drums is less than 100 bucks! Cheap enough. I tow my boat occasionally to the river for a fishing trip and wouldn't want any brake failures. The reason for the brake job is replacing the PO's brakes he did previously.
I was backing the trailer down the ramp to pull the boat out of the water when the brake pedal went to the floor and I almost ended up with the trailer and truck going in the water and sinking to the bottom of the river! I had to do a hard left, jackknifing the trailer and bending the tongue!Bummer, had to fix the trailer too and get towed home by Triple A! :cry:
Ben Franklin.
:drive:
Ranchero50
Post by Ranchero50 »
Ditto. Other than my Mexican cast iron master cylinder that keep draining itself around the lid gasket my brakes have been fine. Found the Chinese drums were a fraction of the cost of Ford's and were a lot heavier construction.
sargentrs
Post by sargentrs »
Ranchero50 wrote:Ditto. Other than my Mexican cast iron master cylinder that keep draining itself around the lid gasket my brakes have been fine. Found the Chinese drums were a fraction of the cost of Ford's and were a lot heavier construction.
Interesting. I had the opposite experience with my Fairlane. Bought new Chinese drums at O'reillys and had to swap 'em twice. They were badly warped right out of the box. Gave 'em back and bought Raybestos drums from Rockauto. Made in Canada and the difference was like night and day. Much heavier and even shaped closer to original. Even cheaper too. Same with the shoes. Bought the Brake Best brand and they cracked during the test drive but that might have had something to do with the warped Chinese drums. Traded them back in and spent the extra money for the Wagner's. Probably still Chinese but better quality.
ThinLizzy13
Dang what a bad time to have the brakes go!
Looking back at my orders now, I got my front drums, wheel cylinders, front shoes, and soft lines through rock auto - all Raybestos.
I got my rear drums and shoes through advance auto - made in China.
This was for my F250. After all was said and done I was in about $300 for all of it. Luckily none of my stuff came warped lol
radioactivelarry
After I installed the left front brake parts I tried to loosen the bleeder and found out it is 10 millimeters instead of an SAE size. What was worse it was on so tight I rounded it off and had to take the brakes apart and remove the wheel cylinder, clamp it in the vice and use vice grips to get it off.
So, I checked the other 3 cylinders and they too were really tight and had to clamp them in the vice and use a socket to remove them. The one I already installed on the front had no room for a socket and that's why I had to remove it. Back to NAPA for replacement of the rounded off one!
My drums were in great condition with virtually no ridge worn in and were well within tolerance. They had "Made in Canada" molded into the drum. Going to do the rears today so I hope all goes well.
:woohoo:
Ben Franklin.
:drive:
