engine
tynall44
engine
Post by tynall44 »
is a 352 the same as a 390 except for the bore and stroke,???? :? :? :? :wel:
Mach428
Re: engine
Post by Mach428 »
https://en.m.wikipedia.org/wiki/Ford_FE_engine
This will tell you everything you need to know
tnlprt
Re: engine
Post by tnlprt »
352 is
4.00 bore block
long rods
3.5 stroke crank
390 is
4.05 bore
short rods
3.78 stroke
by boring the 352 .050 over and installing 390 crank,rods and pistons you would have a standard bore 390
Are the blocks the same ......NO
They have different cylinder core molds
