carb leaking
carb leaking
I have a68 f100 has a 390 2bbl carb.my problem is on the front of carb the square 4 screws pump is dripping out the gasket on bottom,do I have to buy a carb kit,or is there some sealer I can put on it,
- sargentrs
Re: carb leaking
It's a common problem with these carbs. The cover warps over time. Get a sheet of 120G sandpaper and tape it to a hard, flat surface. Take the cover off and, gasket side down, work it back a forth on the sandpaper. The first couple of strokes will show you the high spots. Continue until you have a good flat gasket surface. Won't take much.
Re: carb leaking
I will try that,thanks
Re: carb leaking
While it's apart get a new diaphram too ,no need to buy a whole kit.
