Rusted out dash - not pad
- hillcountryflt
On my project truck the area around the driver's side blower vent (near the radio grille) is pretty rusted out. Is the best thing to do is cut out the spot welds holding in the dash and put in a different one or fabricate a patch or the like?
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
Re: Rusted out dash - not pad
If it's just one small area ,cutting and patching should be ok,if it's along the whole dash then it depends if you are keeping it steel or putting the pad back on.
Pictures would help.
- Ranchero50
I just used a sawzall and cut the whole face off mine when I found a better one. Couple tech screws across the top and the brackets on the bottom kept it tight and looking good.
- calipilot227
Cut out the rusted area, weld in a patch, and then put a dash pad over it so you won't have to worry about making it look nice
Be sure to use seam sealer on the welds, and spray some rustoleum over it so it won't rust again.
My Ford: 1970 F250 Camper Special (360, C6, 2WD, drums all around)
My Daily: 1998 Volvo S70 T5
"In the beginning, God made the light.
Shortly thereafter, God made three big mistakes.
The first mistake was called "Man." The second mistake was called "Wo-man."
And the third mistake was the invention of the poodle."
