I have got a 1994 crown Vic what parts will fit my 67 f100
Motor?
Transmission?
Front end?
Rear end?
Also on the front end conversion what's involved in getting the steering (f100 column and power steering gearbox)connected to crown Vic
Thanks!
1994 crown Vic swap questions
Re: 1994 crown Vic swap questions
A '94 CV will have a 4.6L engine and a 4spd automatic overdrive transmission. If there's a throttle valve cable coming from the transmission up to the throttle body, the transmission is an AOD.
If the transmission has a wiring harness coming off of the side of it, it's an AODE.
The desired years for a CV front suspension swap are 2003-2011. 1994 is too early of a model to do the suspension swap. A 2003-2011 CV would have a 4R70W transmission but, that particular transmission would only be compatible with a 4.6L or 5.4L engine.
A 4R70W from a 3.8L Mustang, 4.2L F150 or a 5.0L Explorer would be compatible with a 302/5.0L engine or a 351W/5.8L engine.
Thanks for the helpful info.
