thought I would share and hope to get comments on this fix
Truck is a 68 4x4 F100
Axle is not, possibly a 73-75, with power steering
The Outer Tie rod I ordered from LMC (68) and the original that was on the truck when I bought, has ball stud in the rod that are too long for the control arm. So when you tighten the nut down it doesn't seat tightly into the control arm.
I am trying to find a 73-75 Outer Tie Rod but cant seem to do that (with PS and for 4X4)
In the meantime I slipped a locking washer onto the tie rod bolt so take up space so that the nut secures down
Driving it feels a lot better than before as there is no play but curious as to if this is a safe fix.
Locking washer is a dense steel
Any thoughts on the fix
