frames
Mr-Dyslexic
frames
Post by Mr-Dyslexic »
Are 65-66 swb frames the same as 67-70 swb frame?
Mr-Dyslexic
Re: frames
bluemoose
Re: frames
Post by bluemoose »
I believe you will find that the 67 on are wider. That is what I believe the literature says about the width of the cab when the redesign occurred. You can find the technical specs on this site for the bumpsides. Not sure where to find the earlier models, but I bet a Google search would do the trick.
