Clunking sound
Bvh56
Clunking sound
Post by Bvh56 »
Hi all. I put new front coil springs on my 68 f250. I now have a clunking/rattle sound when I hit bumps. Anyone else have this occur? Or any ideas on what it is? Thanks
HIO Silver
Re: Clunking sound
Post by HIO Silver »
Something is loose or missing... like the lil metal strap at the top of the spring which holds it to the spring bucket.
. D O A V I S U A L I N S P E C T I O N .
. T R O U B L E S H O O T .
tnlprt
Re: Clunking sound
Post by tnlprt »
Did you get the shocks tight
Bvh56
Re: Clunking sound
Post by Bvh56 »
Shocks are tight. Straps are on and tight. :hmm:
AZf100
Re: Clunking sound
Post by AZf100 »
Now that your springs and shocks are new and back to original you may have some bushings that are not aligned.... :2cents:
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
76Kroh
Re: Clunking sound
Post by 76Kroh »
Check your pivot axle bushings. They may be bad. Mine are shot and make the same noise. New ones will be here tomorrow! :-)
1968 f100 LB 360 4-speed manual :help:
Bvh56
Re: Clunking sound
Post by Bvh56 »
The ones on the arms?
Bvh56
Re: Clunking sound
Post by Bvh56 »
Bvh56 wrote:The ones on the arms?
I mean I beams. It's a 2wd
76Kroh
Re: Clunking sound
Post by 76Kroh »
Yes. I beams.
sargentrs
Re: Clunking sound
Post by sargentrs »
My king pin bushings needed replacing and I had a "clunk" every time I would hit a reflector in the middle of the road. Only on the left side though, right side was fine. Might want to jack up your front end and see if there's any play in the king pins, too.
Bvh56
Re: Clunking sound
Post by Bvh56 »
Ok thanks. I haven't got a chance to get it up on the lift and look yet. I'll check these things out.
habu
Re: Clunking sound
Post by habu »
same here. Only clunked when in reverse and touching the brakes or if I hit a bump/pothole/lane divider reflector the right way. Turns out my bushing and my truck on the drivers side apparently decided they were no longer compatible and the bushing, in entirety, decided to part ways with my truck.
The suspension is currently undergoing a Energy Suspension rehabilitation.
1969 F250 Camper Special, 390 2v, C6, PB, Bendix PS, AC, Dana 60. 3rd owner
Soon rebuilt 390, not stock, will be swapped in.
