Floor pans
76Kroh
Floor pans
Post by 76Kroh »
adult photo sharing
My surprise after pulling out the rubber mat. We don't see much more than surface rust here in Arizona on our trucks. Even more perplexing it rusted from the inside out :? Looking for some advice where to get good quality floors pans.
1968 f100 LB 360 4-speed manual :help:
HIO Silver
Re: Floor pans
Post by HIO Silver »
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
MAK
Re: Floor pans
Post by MAK »
I got mine from Dennis Carpenter and was happy with the quality.
cep62
Re: Floor pans
Post by cep62 »
76Kroh wrote:Even more perplexing it rusted from the inside out .
The rubber mat traps moisture.
While it's apart look for water leaks from under the cowl or the windsheild.
76Kroh
Re: Floor pans
Post by 76Kroh »
I know the heater core was leaking according to last owner. He disconnected it. Doesn't explain the drivers side though. I guess Iwill have to check for leaks.
hillcountryflt
Re: Floor pans
Post by hillcountryflt »
Does the truck have power or manual brakes? The master cylinder on a manual brake truck can leak behind the firewall, under your floor mat and onto your floor plan. I am assuming that would be a mixture that would eat away at a floor plan.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
MAK
Re: Floor pans
Post by MAK »
Mine was leaking badly from the spot the wiper motor penetrated the firewall. Gasket had deteriorated badly and it would pour in during a rain.
Busboy
Re: Floor pans
Post by Busboy »
My 67 was leaking badly from around the wiper pivot shaft gaskets, when I pulled them off the gaskets were rotten.
1967 F-100 4x4 custom cab.
76Kroh
Re: Floor pans
Post by 76Kroh »
It is a Manual but, I haven't seen any fluid. The rubber in the floor for the clutch rod is rotting away though. That could be it but I am thinking it is something else. Sounds like I will be playing with the water hose this weekend. I haven't noticed any leaks before but, since we don't get much rain in Arizona that may have something to do with it! Lol
AZf100
Re: Floor pans
Post by AZf100 »
Mine is an AZ Truck As well and I had to replace the Floor Pan's. just normal 40+ Year repair. its a fairly easy repair, just don't buy cheap.
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
76Kroh
Re: Floor pans
Post by 76Kroh »
AZf100 wrote:Mine is an AZ Truck As well and I had to replace the Floor Pan's. just normal 40+ Year repair. its a fairly easy repair, just don't buy cheap.
Where did you gets yours from?
AZf100
Re: Floor pans
Post by AZf100 »
I Ordered From Dennis Carpenter. you can never go wrong there. I heard other guys talk about saving money and returning them and ordering from DC
76Kroh
Re: Floor pans
Post by 76Kroh »
AZf100 wrote:I Ordered From Dennis Carpenter. you can never go wrong there. I heard other guys talk about saving money and returning them and ordering from DC
Good to know, thx. I will get then there then.
AZf100
Re: Floor pans
Post by AZf100 »
form a guy up in Camp Verde, fairly mild climate. I don't think they're salting any roads up there.
76Kroh
Re: Floor pans
Post by 76Kroh »
Probably not lol. Salt is for margaritas down here.
