Compatible Rear Ends for F250?
colnago
Post by colnago »
I have a '67 F250 Camper Special with a 4.11 rear end. I'd like to swap in a 3.50, to make it more of a daily driver, and have a better gear ratio for highway driving. Does anyone know what vehicles are compatible with my F250 for a rear-end swap? What all would I need to do the swap?
Thanks,
Joseph
Mancar1
Re: Compatible Rear Ends for F250?
Post by Mancar1 »
I have the 4:10 rear in my 68 CS. I plan on taking it to a shop and having it changed out to 3:54.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Mancar1
Post by Mancar1 »
Oh read your post again and u want to swap the rear end out not just the gears. I figure I will be ahead time and in the long run $$$ wise to just take mine to the shop. I am staying with the rear end the 68 has and I believe 3:54 is as high as I can get for it.
I don't think any other rear end is a direct bolt up, it would take modification.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
