All drum brake proportioning valve
- hillcountryflt
I am in a quest for a fully functional proportioning valve for my 1969 F100, 2WD with no power or discs. My proportioning valve is missing the connection for the brake light. Wished I had thought to save the one I pulled off my 71 when I went to disc brakes.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
Re: All drum brake proportioning valve
I have '70 2wd with manual drum brakes as parts truck. I'm not sure on valve condition but supposedly truck was driven less than a year ago before motor blew. I used the brakes to get it of the trailor and it stopped. Is there a way to test it. I put a battery in to test electrics and the brake light was on with the key turned on.
- hillcountryflt
I don't know that these things ever went bad - mine must have suffered a hit to be missing the electrical connection.DannyB1970 wrote:I have '70 2wd with manual drum brakes as parts truck. I'm not sure on valve condition but supposedly truck was driven less than a year ago before motor blew. I used the brakes to get it of the trailor and it stopped. Is there a way to test it. I put a battery in to test electrics and the brake light was on with the key turned on.
How much with shipping to 78028.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
I'll gladly give you the part as the truck is crusher bound in a few weeks. I'll check with PO tomorrow, it shouldn't cost much to ship since it doesn't weigh very much.
- hillcountryflt
Seems like the thing would even fit in one of those "if it fits, it ships" small boxes.
Thank you for the offer.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
Sorry I haven't got back to you. I'm having a time with this thing. I'm gonna have to cut the brake lines off cause the nuts are rounded. When I get it off I'll get your info. It will fit in an If It Fits box.
- hillcountryflt
thanks. I appreciate the offer.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
I got all the lines off but I can't figure out what holds it to the frame. I can't see it very well and there's 3 inches of 45 year old grease everywhere. Do you know what holds it on?
- hillcountryflt
Two bolts coming through the back side of the frame hold the mounting bracket. Alternatively, there are two bolts that attach the valve to the mounting bracket, I believe.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
