car four speed top loader into truck?
Project8046
Post by Project8046 »
Trying to put a 4 speed toploader behind my 72 390 truck. What is all involved in doing this? I know i can't use a truck bell housing but will the clutch and everything lineup with a car bell housing on it?
tnlprt
Re: car four speed top loader into truck?
Post by tnlprt »
Are you using a small or big block toploader
If you have the small block toploader you CAN and should use the truck bell
If you are using a big block toploader you will need a car bellhousing
Some bellhousings will restrict the use of the 11 1/5 inch clutch and require you to use a smaller disc
What clutch bolt pattern is drilled into the flywheel
And just to clarify I am talking about car transmissions
ultraranger
Post by ultraranger »
Top-Loader 4-spd can be wide ratio 2.78:1 1st gear or, close ratio 2.32:1 1st gear.
http://www.davidkeetoploaders.com/idchart1.htm
