64 porterbuilt drop member on a 68?
shibbby911
Post by shibbby911 »
Any body know what the difference is between a 64 and 68 frame?
moon.dog62
Re: 64 porterbuilt drop member on a 68?
Post by moon.dog62 »
More info required. What are you trying to ascertain?
Front suspension is very different in that the 64 are leaf springs and an I beam axel. 68 is twin I beam coil spring an a dirty great big crossmember to suit. Length etc I think is the same I believe.
What is the project? The more info you give us the more we can help.
moon.dog62
I looked at the porterbilt kit and I don't think it is for you. The frames changed between 64 and 65 in the front suspension. I think if porterbilt kit would fit they would advertise it so they could sell more. It may be able to be modified to fit but I guess it won't be a direct bolt in. Alternatively you could look at these guys products.
http://www.nolimitengineering.com/produ ... ort=normal
derbydad276
Post by derbydad276 »
look into a crown vic swap lots cheaper for the same thing
