power steering cooler location
MAK
Post by MAK »
Mounted the power steering gear box and I have a question about mount location for the fluid cooler. The pic below shows the cooler as it was attached to the steering box when I got it. It's likely been bent at some point prior to getting to me. Can anyone tell me where exactly it is supposed to go or if it is even the stock setup? It doesn't look like the cooler photos I have seen of other installations on here. Different versions for different years? Does it mount somewhere to the inner fender?
Thanks
Calfdemon
Re: power steering cooler location
Post by Calfdemon »
That is not a setup that I have seen before, but that does not mean it was not stock to something at some point. All of the PS cooling system that I have seen in our trucks is a single bend that goes up above the pump and then back down. Attached to the single bend are a bunch of small fins similar to a radiator setup. the air passes through and cools.
You can see the very top of the one I am talking about in the picture below. You can see the one bend with a few of the fins before the picture ends. It is probably about inches long and mounts to the top of the PS pump and goes up from there.
I dont have an answer for you on your setup unfortunately...
EDIT: Found a better picture which shows the whole stock setup...
-Rich
Current toys -
Former toys -
abe
Post by abe »
MAK wrote:Mounted the power steering gear box and I have a question about mount location for the fluid cooler. The pic below shows the cooler as it was attached to the steering box when I got it. It's likely been bent at some point prior to getting to me. Can anyone tell me where exactly it is supposed to go or if it is even the stock setup? It doesn't look like the cooler photos I have seen of other installations on here. Different versions for different years? Does it mount somewhere to the inner fender?
Thanks
[ Image ]
Where is your power steering pump?
1970 F-350 flatbed dump, purchased 9/20/12Image
1954 F-100 bought from Grandpa in 1977 for $200Image
MAK
Post by MAK »
Yeah, the one that goes above the pump with the fins seems to be the one I have always seen.
Just found this:
Out of a 77 F150
http://www.fordification.com/forum/view ... p?p=600269
HIO Silver
Post by HIO Silver »
^^^^^ Yup... that's the OEM configuration on the Dents. Bumps had this lil cooler mounted to the PS bracket:
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
MAK
Post by MAK »
Haven't acquired one yet. Still trying to gather all the bits and pieces...
Mach428
Post by Mach428 »
This is a factory set-up as well and was used on later model Ford trucks. The looped cooling tubes mounted to the inner fender.
HIO Silver
Mach428 wrote:This is a factory set-up as well and was used on later model Ford trucks. The looped cooling tubes mounted to the inner fender.
...inner frame rail.
68 Mustang
65 Mustang
