Brake Booster Not Boosting
pincheweddo
Post by pincheweddo »
Brakes are bled, and the truck will stop, as though the brakes are manual. When I hold the brake down and start the truck I don't feel any additional resistance. After running the motor I can pull the vacuum line out of the booster and is still under vacuum. But when I stop, there isn't any power to "power brakes"
Any ideas?
See project updates at:
http://1967f100.blogspot.com
ultraranger
Re: Brake Booster Not Boosting
Post by ultraranger »
pincheweddo
Thanks! This is a sweet write up!
Brake Booster Diagnostics
It is rare that one of our kits will contain a defective power booster but if you suspect that your booster is not functioning correctly perform the following tests:
BASIC TEST
1. With the engine off depress and release the brake pedal several times to eliminate vacuum from the power section.
2. Depress the pedal and hold down with light pressure, 15 to 25 pounds.
3. Start engine.
4. If the power unit is operating the pedal will drop slightly. Less pressure will be needed to hold the pedal down.
IF BOOSTER IS NOT OPERATING GIVING A VERY HARD PEDAL
Disconnect the vacuum hose from the booster check valve and check the vacuum level at this point with the engine running with a vacuum gauge. You should have at least 18" vacuum to the booster. Anything lower will begin to give a hard pedal. lf the vacuum level is below 18" you may be able to tune the engine and bring the vacuum level up to that level. If the vacuum level is around 16" the addition of a vacuum reserve canister will improve the braking. If the vacuum level is below 16" you will need to add an electric vacuum assist pump to supplement the engine vacuum.
If the vacuum level at the check valve is 18" check that the booster check valve is working. Disconnect the vacuum hose at the check valve and attach a piece of tubing. Blow into the valve. If air passes through the valve is defective and must be replaced. Also look into the hose attachment neck on the check valve and be sure there is no obstruction inside the valve.
Check your booster for a vacuum leak. With everything hooked up run the engine at moderate speed. Release the accelerator and turn the engine off. Wait 90 seconds and apply the brakes. If the brake applications are power assisted there is no leak. If there is no power assist the booster is defective and must be replaced.
IF THE BOOSTER IS OPERATING BUT YOU STILL HAVE A HARD PEDAL
Your combination valve may have tripped shutting off fluid flow to the front or rear brakes. This condition will produce a very hard pedal. Check that fluid passes through the valve to both the front and rear by cracking a bleeder screw and observing a good flow of fluid. If one half of the system does hot have flow, re-center the valve.
You may have frozen rear wheel cylinders or frozen caliper pistons. If these components freeze you can get a very hard pedal.
Your pedal ratio may be too low. Check your pedal ratio. The pedal ratio must be in between 4:1 to 5:1. Some of the older cars that had power brakes used a ratio of almost 1:1. If you add a vacuum booster to this type of car you will have a very hard pedal. Typically we are talking about late 50's cars. Adjust ratio as necessary.
Your booster may be undersized for the weight of the vehicle or the bore size of the master. If you try to use a small diameter booster such as a 7" street rod booster for a heavy car you will get a very hard pedal. Compounding the problem is an attempt to use a large bore master (1-114" or larger) on a small booster.
IF YOUR BRAKE PEDAL IS VERY SENSITIVE AND THE BRAKES GRAB
Your pedal ratio may be too high. Power brakes will require a 4:1 to 5:1 ratio. If your ratio is around 6:1 you are getting too much mechanical advantage making the brakes extremely sensitive. Adjust the ratio to correct level.
The booster may be too large for the weight of the vehicle. Lightweight vehicles with large boosters give you "touchy brakes”. This effect may be dampened somewhat by going to a larger bore master.
Too large a booster for front drum brakes. Drum brakes do not require as much pressure as disc brakes (500 psi vs. 1,000 psi). If your booster is very large (11") and you have drum brakes you are over-boosted. Do a pressure test to determine what you have.
The booster has a cracked internal hub. When there is a crack in the phenolic hub inside the booster it will be either totally on or totally off. Any slight pressure to the pedal will cause the brakes to lock up. The booster must be replaced.
