Factory Air 1970 XLT Ranger
Have the rarer factory air in my 70f100 and everything is there.Wonder is it difficult/work resurrecting? As is now the heater core has been bypassedand the fan is not turning on.How hard are these units to service. Is there some unobtanium parts there?
- ToughOldFord
Re: Factory Air 1970 XLT Ranger
The parts are still available, and it is doable. But it is a PITA. Check/replace your hoses, all the orings, replace the dryer, expansion valve, if it's been down long the compressor too. Flush the system, retrofit to R134.
I did it to mine (dealer add on), not happy how much time I wasted on it, and the freon ended up leaking out the old York compressor. If I ever put the truck back on the road I'm going to put a Sanden compressor in it.
If you're bored here's my AC saga:
http://www.fordification.com/forum/view ... &sk=t&sd=a
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
I'd be worried about the evaporator core. If it is OK, you should be able to get it running.
Because the heater core has been bypassed, you'll probably need a new one. As for the fan, it could be the switch, the fan motor, the resistor module or who knows what.
Unless you are bent on keeping the truck box-stock, you might want to consider using a Sanden style compressor as has been suggested. There's a seller on eBay who has them for a very reasonable cost. Here's one example but he has others with adapter mounts, hoses, fittings, etc:
http://www.ebay.com/itm/400453945100
If you can get the system nice and tight and have access to R-12 refrigerant, that is your best bet performance wise. Many people have switched over to R-134a. But, there are quite a few who believe their systems performed better with R-12. Some say it has to do with the size of the condenser coil. That is, you should increase the condenser size if you switch to R-134a. Not having done so, I can only pass along what I have read.
I kept my system on R-12 when I changed the compressor. But, when I add air conditioning to my other truck, I just might use R-134Aa. I've already purchased the largest condenser I could find that will fit in the space available. And, it is a good bit larger than the stock coil used with R-12. So, it should be OK for both refrigerants. I managed to snag some more R-12 last week and R-134a is easy to get.
Good luck with it.
Good luck with it.
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
68 F100 Ranger
73 F100 Ranger XLT
