no-spin rear?
no-spin rear?
I have a 69 F250 with open 10 bolt rear, it sucks. I found a junked '72 C20 with a No-Spin rear, 10 bolt round cover, for $100. would it be worth it to adapt this rear to my ford? or can I simply take the locker out of the chevy, and install in the ford? both are 3/4 ton trucks. Thanks!
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
Re: no-spin rear?
Just get a locker like power trac from Richmond. Or find a trac lock rear from another ford. I wouldn't think a chevy locker will fit in a ford rear end
- HIO Silver
Re: no-spin rear?
Dude, gotta straighten out your use of terminlogy to avoid confusion. Your rig has a Dana 60. Yes it has a 10 bolt cover but referring to it as a 10 bolt is wrong. A "10 bolt' commonly refers to GM's light duty rear axle like in Camaros and Malibus. Its big brother is the 12 bolt... a heavier duty, performance oriented axle.Bill Ramsey wrote:I have a 69 F250 with open 10 bolt rear, it sucks. I found a junked '72 C20 with a No-Spin rear, 10 bolt round cover, for $100. would it be worth it to adapt this rear to my ford? or can I simply take the locker out of the chevy, and install in the ford? both are 3/4 ton trucks. Thanks!
And the term 'no spin' is a term used by Dodge, IIRC.
Lastly, a locker is different from a limited slip which is what you may be referring to.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- HIO Silver
Re: no-spin rear?
Double post.
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Re: no-spin rear?
The 3/4 ton Chevys did not come with a Dana 60. Chevy had their own rearend that had a 10.5 in ring gear & only came in 2 gear ratios. 4.10 & 4.56. The thing is damn near indestructible, but the lack of replacement gearsets is a pain in the butt.
I had a '72 3/4 ton Suburban that I absolutely loved. You could tow a building with a 327, but no matter what, it only got 8 mpg. It needed Overdrive!
If common sense was really common, wouldn't everybody be using it?
Re: no-spin rear?
yes i know its a dana 60, and it has 10 bolts. the chevy rear is an eaton with a round cover, also 10 bolts. the eaton is a FACTORY detroit locker. G86 no spin is what it IS called.
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
Re: no-spin rear?
This truck might tow a 3k lb trailer around the state at most. The 351 is nothing special and I am not gonna hot rod it. I just want OD and reliability. Help me out on these prices and give me your opinions or experiences, I would really appreciate it. Thanks!
RUKHSANA
